Know who makes wheel speed sensor?
Old Oct 27, 2021 | 11:29 AM
isthisusernameavailable's Avatar
Default Know who makes wheel speed sensor?
Looking for a new right front wheel speed sensor for a 2007, but these seem to be on back order and could take months...
OEM part number is 57450-S2A-003
Does anyone know the manufacturer/model # of the OEM sensor (if the sensor is made by another company and just branded as Honda) ?
A search on Rock Auto shows three compatible sensors:
WVE 5S7489 for $114.79
NTK AB1806 for $156.99
Standard Motor Products ALS1566 for $161.79
Has anyone used any of these particular aftermarket sensors with good result?
Which would you guess is closest to OEM?
Old Oct 29, 2021 | 07:26 AM
B serious's Avatar
Not sure who supplies the sensor to Honda. I haven't seen any markings.
NTK supplies a ton of other sensors on this car. It would be a good bet.
Or buy a used one on eBay.
Old Oct 30, 2021 | 04:26 AM
Mr.Matchbox's Avatar
NTK = NGK. Like DENSO, a very reputable brand.
Old Oct 30, 2021 | 06:13 AM
SheDrivesIt's Avatar
Note that the OEM part linked from hondaautomotiveparts.com is cheaper than the NTK at Rock Auto.
Old Nov 3, 2021 | 03:51 PM
rrounds's Avatar
WVE, NGK, NTK, WPT and GO TECH are all one company. I'd try the WVE for $115. All it has to do is work, if it doesn't, send it back.
Bottom of page shows all the company's
https://wvebrand.com/company.html
Rod
Old Nov 15, 2021 | 04:27 PM
Thanks for pointing this out. Would have been open to a WVE after seeing this post, but luckily OEM came sooner than expected!
In case anyone else is interested down the line, markings on the new part include "S2A-FR-000" in white dot-matrix alpha-numerics on the cable, "S84" stamped on one of the metal brackets, and "R" stamped on the other two brackets. Most of the white letters had abraided off of the original part from the car.
s2000adventures
Oct 13, 2019 11:46 AM
gandalf12
May 27, 2015 01:31 PM
pemex70
Oct 4, 2007 09:40 AM
dmpts2k
Feb 20, 2006 05:19 PM
