Knuckle replacement
Old Jul 18, 2005 | 04:47 PM
cyberhide's Avatar
Default Knuckle replacement
I recently had a bad encounter with a curb that messed up my lower ball joint (and wheel) pretty bad. I have removed the knuckle in preparation to have a new wheel bearing and knuckle pressed onto the hub. But I need to know what tool would work best to reinstall the ball joints for the lower, upper, and tie rod.
Also, whats a good way to find out if my lower arm has been messed up, atleast the receiving joint? It looks a little out of whack, but without the new knuckle, i cant really tell if the ball joint receiver is out of shape.
Any general wisdom or help on my current suspension woes is also welcomed.
Thanks guys,
Chris
Old Jul 19, 2005 | 06:28 PM
cyberhide's Avatar
Well. I removed the lower ball joint from the knuckle, and verified that it wiggles around in the lower arm receiving joint. Guess I'll be replacing my lower arm as well. I know I will probably need an alignment done after this, but is there anything else I'm missing?
-Chris
Old Jul 22, 2005 | 08:49 PM
cyberhide's Avatar
Oh c'mon.. no one's done suspension work before?
I'm gonna go ahead and order a new lower arm and knuckle and see how it goes. I'm hoping my alignment comes back ok. *fingers crossed*
-Chris
AlyWW
Dec 25, 2023 10:36 AM
raneyboo
Apr 28, 2011 07:18 AM
vassosva
Feb 1, 2010 07:43 PM
v2deLsoL
May 28, 2007 07:47 PM
