Kpro question ? Need help
Old May 18, 2015 | 05:48 AM
lude9285's Avatar
Default Kpro question ? Need help
Turbo kit is installed and using kpro .
My Plx wideband is reading afr's but the Kpro is not data logging, it just reads a constant 14.7 on my laptop .
I have verified that the wideband is set up correctly . The Green/red EDL wire has been cut in the fuse box under the hood and the wide band 0-5 bolt wire is t-tapped into Pin 30 of the ECU.
I used a multi meter and verified that the wideband is outputing 3.5 volts and that there is continuity in the green/red EDL fuse box wire to where it plugs into pin 30 of the OEM ecu harness .
But the Kpro is stil not data logging. Is it a software issue? Is there a tap somewhere that i need to turn on to start data loggong ?
Thanks
Joel
lude9285
May 19, 2015 03:46 AM
Red_Ohio_Rocket
Feb 22, 2005 09:18 PM
WR58
Mar 25, 2004 11:21 PM
Asura
Feb 26, 2003 09:11 AM
