Larger injectors + higher boost pulley = problem?
Old Oct 28, 2004 | 06:33 PM
mkell's Avatar
Default Larger injectors + higher boost pulley = problem?
I was wondering if I could swap out the pulley for a a higher boost pulley (9psi?) and get larger injectors (RC550?) would it be somewhat safe? I also heard that you need to get a different head gasket...what one should I be looking at? I want to get some more horsies under the hood, but I don't know if I can afford cams, pistons, etc. Please enlighten me on any other routes or any info relating to my questions. Thanks!
-Matt
Old Oct 28, 2004 | 06:39 PM
revhi's Avatar
Add an AEM computer and some dyno time and you should be fine.
Old Oct 28, 2004 | 06:42 PM
mkell's Avatar
What head gasket should I be looking for? I am kind of in the dark here.
Old Oct 28, 2004 | 07:02 PM
revhi's Avatar
I dont think you need a different head gasket. You should be safe with the stock one at 9 psi.
Old Oct 28, 2004 | 07:20 PM
mkell's Avatar
sounds good to me...
Old Oct 29, 2004 | 01:03 PM
mkell's Avatar
Where could I find a gigher boost pulley?
Old Oct 29, 2004 | 01:38 PM
dut's Avatar
dut
- tech2 has some on his site.
- what are you running right now? 5psi 7psi?
Old Oct 29, 2004 | 01:39 PM
dut's Avatar
dut
^ oh, here is the address http://www.tech2motorsports.com/cat/catalo...b6134f53639042b
Old Oct 29, 2004 | 01:45 PM
mkell's Avatar
thanks for the link! I am running somewhere between 7-8psi.
How much rwhp should I gain with a 9psi pulley, aem ems, rc550 injectors, and godzilla bov?
Old Oct 29, 2004 | 01:49 PM
dut's Avatar
dut
- didn't bigpurp dyno something around 337hp? not sure what he has though...
- you running stock injectors and ecu with that 7-8psi?
