LE1605...
Just recieved my quart of LE1605 from Hardtopguy, and I'm a little confused about it. I've used LE607 for a couple years now, which was a 90w. I noticed on the 1605 bottle that it says SAE 110... so it's a 110W, correct?
Just curious if this is going to be ok. Any help would be great! Thanks!!
Originally Posted by SpitfireS,Aug 28 2008, 08:43 PM
It is what is is: SAE 110 (not 110W)
Just like LE-607 is SAE 90 (not 90W)
RadioZero is right: SAE changed the ranges and thick SAE 90 (what LE-607 is) is now called SAE 110.
The only time they use the letter "W" (reserved for so to speak) is for winter grade characteristics of multi-viscosity crankcase and gear oils. Those would be for the crankcase: 0W, 5W, 10W, and 15W. The winter grade gear oils characteristics are 75W, 80W, and 85W. All the other SAE gear oil and crankcase oil viscosities are listed just as a number because they didn't meet the industry cold standards for labeling as a multi-vis grade. So when you see a bottle labeled with 10W-30 or 75W-110, the 10W and 75W tells you what that lubricant's winter (pour point/cold cranking) viscosity characteristics have met via certain testing parameters.
So, the bottom line is that W stands for winter, not weight as it relates to lubricants.
neveronlines2k
Oct 17, 2007 11:47 AM
