Leaking oil from hex bolt
Old Jun 30, 2011 | 05:48 PM
abnormals2k's Avatar
Default Leaking oil from hex bolt
As the title states, that hex head bolt on the front of the motor right underneath the valve cover leaks oil. I dont even know what that bolt goes to or what its called. And I've never seen it leak oil on any other s2k's. Help is appreciated...
Old Jun 30, 2011 | 06:17 PM
AusS2000's Avatar
I guess you're referring to the timing chain upper cog axle. It has an O-ring around it to keep oil in. Guessing it has failed.
You would need to get an O-ring either from Honda or a compatible one. One of the mechanics will be able to tell you whether you can get access to the O-ring just by loosening the bolt/axle a bit or whether you have to pull the valve cover and hold the upper cog in place whilst you completely remove the bolt.
Old Jun 30, 2011 | 06:29 PM
poorshoeless's Avatar
Follow the link below... Good Luck..
https://www.s2ki.com/s2000/topic/832..._fromsearch__1
Old Jun 30, 2011 | 07:13 PM
AusS2000's Avatar
That'll do it.
Old Jun 30, 2011 | 07:56 PM
Oh shnap! Thanks fellas
JrJanowski
Jul 15, 2018 10:16 AM
jimreaper
May 17, 2014 06:50 PM
sound_wave
Oct 20, 2013 01:37 AM
_brandon
May 12, 2012 05:16 PM
folex187
Jan 31, 2006 05:29 PM
