Tiny oil leak
Old Oct 1, 2013 | 11:07 PM
sound_wave's Avatar
Default Tiny oil leak
Hello folks,
Checking the oil level over the past couple of weekends (check it religiously) and i've noticed that there is the tiniest of oil leaks coming from what looks like the timing chain sporcket bolt hole. (the hex bolt thing that is slap bang in the front of the cylinder head)
It seriously is like a dribble.
Wiped it away and a week later, it's back.
Any ideas as to what could be causing it? Is there a tiny seal / oil ring in there that could have moved? Is it a big job to replace, or is it simply get that bolt out and replace the seal?
Thanks
Old Oct 1, 2013 | 11:25 PM
unclefester's Avatar
Yes - there's an O ring in the back of that which may need changing but you really need to read up on the how and why as if you remove that bolt too far when changing the seal you can drop the entire timing assembly down into the guts of the block
From memory ( you need to search again) you wind the bolt out just far enough to get at the O ring but there is a specific torque that must be adhered to when you tighten the bolt up.
Old Oct 1, 2013 | 11:28 PM
tozerman's Avatar
Piece of cake to do just follow this link https://www.s2ki.com/s2000/topic/832...g-weeping-oil/
Old Oct 2, 2013 | 12:36 AM
sound_wave's Avatar
Jesus, there isn't ever anythign with this car that doesn't have consequences is there - unscrew too far and you loose a sprocket, don't screw back in tight enough and you get crank walk!!
Old Oct 9, 2013 | 06:04 AM
sound_wave's Avatar
Ok the Honda manual states 49NM to torque this down to. Do I go tighter, knowing Honda?
Old Oct 9, 2013 | 11:30 AM
Nick Graves's Avatar
If you want to deform the new washer & cause another leak then yes.
Honda TQ settings are usually pretty tight. It's just that nasty harmonic around the front that makes it whine & shakes the plugs & filter loose.
Old Oct 20, 2013 | 01:37 AM
sound_wave's Avatar
Fixed this yesterday with Ray's help. As soon as we got the ring off, it crumbled in our hands. Definitely a part to replace every so often.
toniotran
May 23, 2015 12:55 PM
Peti
Dec 17, 2014 04:48 PM
Le408
Nov 22, 2011 02:24 PM
SPECIAL-OPS-S2K
Jan 22, 2008 04:17 AM
folex187
Jan 31, 2006 05:29 PM
