Leaking - Water in Boot - Trunk (pics+fix)
Originally Posted by ndtinker' timestamp='1367809543' post='22521535
[quote name='TW00Si' timestamp='1360776312' post='22335055']
What's a good way to remove the material that sits under the trunk lining and spare wheel compartment? Is a plastic scraper sufficient?
[/quote]
Old commercial/airline trick for removing gum in carpet and all kinds of stuff was to spray freon on it to freeze and then scrap or break it up. Can't do freon now (not supposed to) but compressed air (tilt to get liquid) can do it to.
I'm in the middle of cleaning up the rust in my 2002 trunk due to water getting into the trunk. After removing the carpeting to expose the rust, there is a plastic type sheet/pannel that seems to be glued on to the metal of the trunk (where the plastic plugs are).
My plan was to sand out most of the rust, treat it with rust remover, then seal it with something like POR-15. However that plastic sheet is in the way. I'm thinking I need to take it off somehow, so that I can get at the rust which is underneath it. However, it seems to be glued on pretty well, and taking it off seems pretty time consuming.
Does it need to come off to remove the rust properly? How did you guys manage to take out the rust under that plastic?
Thanks in advance
Thanks in advance
Is it okay if I drill a tiny hole in the trunk bottom, incase it fills up in the future? I had leaks that I fixed a while ago but when taking all my tools and other junk out of the trunk, I found the bottom was still wet. Taking of the lid, exposing the oem toolset, I found the bottom was filled with water! Even the toolkit was in water.
I think the leakages have been fixed, so I think its old water being there for quit some time.
Now I figure if there would have been a tiny hole in the bottom 99% of the water could have dripped out?
I think a tiny hole cant harm anything, I dont think water will come in from below the car, its quit a distance to the wheels in case of driving thru rain?
and with the toolkit and lid on top its also quite sealed from the trunk.
Has anyone tried this?
What do you guys think?
thanks
thanks
Think is not good enough. Make sure your leak is fixed.
Remove panel to the spare tire, remove the toolkit and shine a flashlight in the trunk. Take a few gallons of water (top up) and pour it all around the top and see if you spot any leaks.
I personally fixed my leaks and then popped a small hole in the plastic "drain" piece that is below the toolkit in the trunkpan -- using a flathead screwdriver or drill.
Why did you still make a hole although you tested all leaks fixed?
Did you test the hole itself afterwards with water to see if it drains?
Do you notice any moisture or humidity in the trunk due to the hole you made?
How big did you made the hole? Like a few millimeter or bigger?
thanks again!
Thanks for advice!
thanks again!
thanks again!
I'm in California, it's garage parked, and therefore no moisture or humidity issues. I just made a small ballpoint-pen tip sized hole or two in the plastic cap at the bottom of the trunk pan. Probably too small to evacuate any water, and no I did not test drain it.
For the record, maybe 8 years ago I found a leak coming from the top of my quarter panel near the antenna hole -- I had to remove the "Molding, R Rear Windshield" (https://www.hondapartscheap.com/oem-...74307s2a003zd/ ) and seal the seam of the quarter panel with RTV -- likely exasperated with clogged drain holes (which I also cleaned out).
And years later, per above, I had a leak with my new Robbins top installation with the un-riveted and unsealed) holes in the rain rail.
