Left Rear wheel Hott?
Old 05-01-2011, 10:31 PM
S2K2226's Avatar
Default Left Rear wheel Hott?
Drove to the corner store today, when I got home I could tell something was hot from the left rear, and noticed my wheel was very hot.I am thinking the brake was sticking or somthing.I did not drive with the E-brake on,and It was a fairly short trip.I havn't done any work on the brakes since last year "brakepads". any Ideas?
Old 05-01-2011, 11:21 PM
MP2k's Avatar
A pad is dragging or the bearing is going out. Can you hear anything? Jack the rear up and see if the wheel has drag to it or see if you can feel any roughness in the bearing.
Old 05-01-2011, 11:30 PM
toniotran's Avatar
, sounds like a wheel bearing
Old 05-01-2011, 11:31 PM
S2K2226's Avatar
Wheel has drag,and I don't hear any noise.So, I took it off. and the brake pad was dragging or stuck? now I have them off and I took the caliper apart and I don't know where the slider bolt that is smooth goes,I didn't know they were differant until it was to late. now ,I still don't know why the brake pad was rubbing.and now I am stuck.... help? lol
Old 05-01-2011, 11:57 PM
MP2k's Avatar
Smooth on top. The pins need to be greased and free to slide. Also make sure the grooves that the pads sit in and slide are not all corroded. The caliper piston could possibly be seized too, but thats not as likely.
Old 05-02-2011, 12:07 AM
S2K2226's Avatar
Awesome feedback.. I will let you know what I find out.Thanks.
Old 05-02-2011, 03:30 AM
s2000maniac's Avatar
do the pins differ for the front caliper too? i'm talking about the smooth pin. thanks
Old 05-02-2011, 11:37 AM
SpitfireS's Avatar
Rear pistons do seize, even when the sliding pins don't.
Old 05-02-2011, 01:52 PM
when you push back the rear caliper piston... is it clock wise or counter clock wise? and what kind of tool do you use?
Old 05-02-2011, 02:38 PM
Bror Jace's Avatar
I used to sell brakes ... my first guess is a seized/sticking caliper. Need to get a rebuilt caliper.
I have followed cars and could smell the burning brakes ahead of me. Sometimes you can see smoke pouring out the wheel well (Ford Mustang).
Quick Reply: Left Rear wheel Hott?
