License plate light doesn't work?!
Old Jan 27, 2009 | 06:45 AM
TakmaN's Avatar
Default License plate light doesn't work?!
I have recently tried swapping out my license plate bulb to those "xenon white" LED type bulb and realized that my OEM and LED bulbs did not work when I wanted to take some before and after pictures. I believe my license plate light worked before, but now I'm not so sure. Are there any more common reasons as to why it doesn't work? The wiring seems to be fine but then again, I know nothing about wiring/electrical components.
Any tips or help on things I can check for would be great!
Old Jan 27, 2009 | 07:56 AM
daktruckie99's Avatar
Is the wire connected behind the bumper cover? There is a harness clip so that the bumper can be removed.
Check the socket coming out of the car for power first.
Old Jan 27, 2009 | 11:58 AM
terahertz's Avatar
turn the bulb around. led ones will only work one way.
Old Jan 27, 2009 | 03:43 PM
S2Sloww's Avatar
^^ turn it around, oneway power
Old Jan 27, 2009 | 03:55 PM
He said OEM bulb wasn't working either.
Old Jan 27, 2009 | 04:39 PM
S2Sloww's Avatar
10-4 misread, could it be the fuse/ connection Truckie99 stated above.
Old Jan 28, 2009 | 07:30 AM
TakmaN's Avatar
Thanks guys, any idea how I can go about checking the fuse/connection? I looked at the wire in my back bumper and it appears to be connected fine. I know nada about electronics, car fuses, car electrical systems, etc. so if someone can direct me how to check the fuse and further check the connection that would be awesome.
I also notice that my dash panel lights (e.g. the air controls and radio controls) go on and off. A part of my a/c controls lighting (where you can select whether you want the air at your face, feet and face, etc.) did not light up when I bought the car and a few months later, it's now on?! My CH button on my radio controls lit up fine before as well and now it doesn't. Seems a bit odd, but I'm going to wait and see if it turns back on again. I do know the previous owner had a sound system installed, could this have funked with the electrical and lighting system at all?
jimmychowder
Aug 13, 2010 11:14 PM
s2000maniac
Jul 9, 2010 08:02 AM
TitusS2k
Feb 9, 2008 03:56 PM
NFRs2000NYC
Apr 1, 2007 04:46 PM
freak21s2k
Mar 12, 2007 08:49 PM
