Light relay
So signals and hazards don't work. Changed relay to an aftermarket and all blown fuses. All worked well for first 12 hours and then stopped outta nowhere. Changed fuses again and put new relay(same brand) "Flasher EP34" by Novita. Just keeps blowing fuses. Any ideas?
What do you want us to say? We can't and won't find the bad wire for you. In your case check for continuity, when you find the wire with high resistance that's the problem. Check the grounds, other than that, it's a pain in the ass detective work and nothing we can say will change that.
Mannn
Feb 5, 2004 06:48 AM
