My Srs Light Is On.
Old Jul 12, 2004 | 09:33 AM
Karl O.'s Avatar
Default My Srs Light Is On.
Had some problems with radio fuse blowing, ended up being part of mobile phone charger fell off and was stuck in the power outlet, causing blown fuses. I initially could not determine which fuse controlled the switched ignition wire, now I know it is on the accessory socket fuse.
However, after pulling several fuses out of the fusebox to determine which one was blown (with the ignition off) my SRS light stays on. I disconnected the negative battery cable for about thirty minutes but that did not work. Any ideas?
I have an appointment with the Honda dealer tomorrow morning to have the code cleared but I was hoping there was another way. Thanks.
Old Jul 12, 2004 | 10:39 AM
xviper's Avatar
You should double check the SRS fuses. You could have blown one just by pulling it out and pushing it back in funny.
Old Jul 12, 2004 | 11:07 AM
Karl O.'s Avatar
That's a good idea, I will check that when I get home. I just can't imagine that I damaged the SRS module by checking the fuse.
Old Jul 12, 2004 | 12:08 PM
03spa's Avatar
You may have accidently pulled a wire out while under there with the fuse box. I did that the other day, it drove me nuts for a few hours to figure out what I did to cause the SRS to go on.
Also I had a similar problem about a year ago, the car was in the garage with the dome light on for about a month. Needless to say the bat was dead.
I jumped it and still had SRS. Brought it into honda and they had to reset the system. They said that it's not uncommon for the SRS light to activate if the bat is dead for a long period of time.
Old Jul 12, 2004 | 05:00 PM
Karl O.'s Avatar
I finally found my Honda guru mechanic (he lives 150 miles from me), he said that anytime the SRS circuit loses power the ECU pops the SRS light on. He said that I could reset it with a jumper if I knew what I was doing, think I'll just let the Honda dealer reset it. Don't wanna fry something else trying to save $20.
Old Jul 12, 2004 | 05:11 PM
Slows2k's Avatar
Low battery voltage can cause a SRS DTC, but you really need the DTC pulled to verify that's what the problem is.
jpark
Apr 17, 2023 04:00 PM
japcrap
Dec 26, 2014 09:09 PM
skylinrcr01
May 27, 2013 10:58 AM
sanchoii
Nov 3, 2012 06:40 PM
captainbk
Dec 3, 2006 07:09 PM
