Link to diy timing chain replacement?
Old Jul 10, 2018 | 07:17 AM
  #21
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
10 is the spindle.
The bushing is inside part #11. Likely not available separately.
Old Jul 10, 2018 | 07:35 AM
  #22
912S2k's Avatar
Updated parts list
Old Jul 10, 2018 | 10:34 AM
  #23
Billman250's Avatar
Top Answer: 1
Get the spindle, and you are set.
And grey permatex rtv silicon.
Old Jul 11, 2018 | 08:21 AM
  #24
912S2k's Avatar
I think I'm going to hire someone to do the install. I'm still uneasy about setting the timing on the car and I'd rather pay someone $800 to do the install than **** the timing and then have the tow the car to someone to fix the timing.
Old Jul 11, 2018 | 08:32 AM
  #25
dedonderosa's Avatar
Originally Posted by 912S2k
I am going to need to replace my timing chain. The Ballad Sports TCT stretched my chain and I can hear it whining while driving the car. Will I need to replace the guides as well?
might as well replace them while your in there.
Old Jul 11, 2018 | 10:21 AM
  #26
kraquepype's Avatar
I'm beginning to worry I've got a similar situation going on, I installed a Ballade TCT last oil change and it sounds like my valvetrain is getting noisier. I had no issues at all with the install though, the TCT slid in without any resistance and went in flush. Backed the screw holding it together out as described in install too.
Do you have a video or example of what your car sounded like?
Old Jul 11, 2018 | 12:36 PM
  #27
912S2k's Avatar
I do but the sound is hard to hear. It sounds like timing chain slap coming from the front of the valve cover.
Old Jul 11, 2018 | 01:01 PM
  #28
kraquepype's Avatar
Thanks... is it at a particular RPM? I notice increased valvetrain noise while driving, especially in areas where the sound can be echoed back, it isn't a whine though. At first I thought it was an exhaust leak but replacing the main donut gasket didn't really change it.
Old Jul 12, 2018 | 06:26 AM
  #29
912S2k's Avatar
The sound gets louder as RPMs increases.
Old Jul 12, 2018 | 11:29 AM
  #30
roel03's Avatar
Timing on this car is super easy to set.
If you can do the timing chain, setting the timing is a cake walk.
Line up the mark on the crank when cyl 1 is on TDC. Then line up the idler gear marks to be parallel with the head. Then the camshalfs to be at 11/2 with the marks pointed at each other. Done. Takes all of 5 minutes.
