location of hole in heat shield
I am planning on keeping my stock heat shield and was wondering what diameter hole is needed in the heatshield. I am not sure how much movement the ETD makes and dont want it to rub. Also, if anyone can tell me the location (measurements from the top and side of the shield) where I should make the hole, it would be greatly appreciated.
Thanks in advance.
Thanks in advance.
That's not true. I've mounted a cusco front strut tower bar with a J's racing damper with no problems. I'm sure a lot of other brands will also fit with the J's damper.
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
Then you are stackiing a STB on top of the J's bracket.
You must be using non-OEM shocks, because the stock shock mounting studs aren't tall enough for putting both on and having threads showing above the mounting nuts.
It's not designed to be used with another STB.
Yes, I did stack the STB on top of the J's bracket for the damper.
Also, the shocks are oem and there seemed to be plenty of thread to put the nut on but you are correct, there are not enough threads to be shown above the nuts.
Although not designed to be used with other strut tower bars, it can be done safely.
The car has seen track days and many street driven miles without any issues thus far.
Former Sponsor
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
