Looking for 46960-S2A-A00 Clutch Steel Line!
Old 04-03-2023, 03:33 AM
Billman250's Avatar
Received 1,265 Likes on 772 Posts
I have the hardline if all else fails.
sebo (04-03-2023)
Old 04-03-2023, 03:41 AM
Billman250's Avatar
Being that the hardline is steel and the MC is aluminum, the line is likely fine.
Look at the angle that the line is going in. If it doesn’t look straight, use a 10mm wrench on the fitting to bend/tweak the line until it is straight. Use pliers on the end of the 10mm wrench.
windhund116 (04-03-2023)
Old 04-04-2023, 08:06 AM
Car Analogy's Avatar
Received 1,320 Likes on 998 Posts
This is the sort of task that experience is invaluable. Anyone who has wrenched for many years has run into issues like this. Something simple that just won't go.
You learn the tricks. When to just use more force, and when to stop and reassess. When to definitely not use more force.
You also get better at hand eye coordination and manual dexterity. Like is required here.
After loosen mounting like Billman suggested, and tweaking the line if its not going in straight like he explained, do this:
Slide line all way in so flare bottoms out in hole. Its easier to visualize line misalignment this way.
Next, screw fitting BACKWARDS, while applying slight inward pressure. You'll feel a point where fitting falls off ramp of last thread, and pops in slightly. That means threads now perfectly aligned to start engaging.
Now that threads aligned, try hand tightening fitting, while keeping pipe straight.
Anytime you have threads that aren't cooperating, won't engage, try this backwards trick. Feel fastener fall off ramp of last thread, and you'll know threads now aligned to engage.
The following 2 users liked this post by Car Analogy:
Mr.Matchbox (04-04-2023), windhund116 (04-04-2023)
Old 04-04-2023, 08:42 AM
windhund116's Avatar
Received 1,437 Likes on 964 Posts
This is the key. I always rotate the nut or bolt by hand. It's easier to feel when the threads align --- and "drop" into a mating position.
Care is important. You do NOT want to cross-thread brake lines, for sure.
Old 04-04-2023, 09:09 AM
Mr.Matchbox's Avatar
Exactly. This works with every screw and bolt to, of course.
If everything fails, every car shop should be able do make a new steel line, using the old used or damaged one as pattern.
Or simply buy a steel braided one, custom made. There are some around allready, just a example: https://auto.helperformance.com/hel-...and-drive-1999
Old 04-08-2023, 10:24 AM
treimche's Avatar
If you still need the hard line, I should have one laying around.
flanders
04-23-2018 02:55 PM
Gaffa
05-11-2015 05:55 AM
jln66
07-15-2011 01:58 PM
Mr Ak
09-10-2009 04:20 PM
killabee
07-17-2009 01:27 PM
Quick Reply: Looking for 46960-S2A-A00 Clutch Steel Line!
