vtec cutting in-out over 6000
Old Mar 30, 2008 | 03:44 AM
kohl-smith's Avatar
Default vtec cutting in-out over 6000
Hi everyone just seeing if anyone can help out...... when i'm going over 6000 revs the vtec power cuts in and out and doesn't seem to be consistant some days it'll work then won't, just wondering if anyone has any answers for me?
Old Mar 30, 2008 | 04:40 AM
Midwife kwisis's Avatar
If the engine has not warmed up completely, this is normal. VTEC-limiter prevents red-lining a cold engine.
Old Mar 30, 2008 | 05:42 AM
kohl-smith's Avatar
Yeah i am aware of that.... the power cuts in and out in that 3000 revs range with a warm engine
Old Mar 30, 2008 | 06:06 AM
SpitfireS's Avatar
Oil level is ok?
MAP sensor connector?
(search for MAP whack)
VTEV solenoid oil screen.
Any CEL(Check engine light)'s?
Old Mar 30, 2008 | 06:12 AM
ruexp67's Avatar
VTEC is driven off of oil pressure. So low oil pressure for any reason can cause this.
On the simple side, it could be low oil level.
On a slightly more difficult level, it could be a vtec solenoid.
The worst case scenario is that you could have a spun bearing.
Old Mar 30, 2008 | 06:21 AM
XLR858's Avatar
Did you tamper with your TPS setting? Have honda put it back to original / correct setting - this may solve the 3000 rpm "stutter".
Old Mar 30, 2008 | 08:51 AM
Saki GT's Avatar
Whack the MAP.
Old Mar 31, 2008 | 04:00 AM
kohl-smith's Avatar
Thanks for the suggestions, the car hasn't been changed or modified in anyway and oil levels are good. I've been told the engine may just need a good run being a performance engine it may have just gummed up? I'll get the solinoid checked out as well thanks again.
Old Mar 31, 2008 | 05:00 AM
ruexp67's Avatar
I don't know about "gummed up." That's a way of saying "I don't know what is wrong."
How many miles are on the car?
Old Mar 31, 2008 | 11:14 AM
PWRMKR's Avatar
Seeing that you have a MY2000, check to see if Technical Service Bulletin 04-073 has been performed. Look at the MAP Sensor and see if it has a tie wrap holding the connector in place. If not, go buy one, install it, and report back, please.
Map Sensor Whack, you can stop whacking it now
