Loss of power/flashing CEL
Old Aug 12, 2014 | 04:45 AM
cjfrederick's Avatar
Default Loss of power/flashing CEL
I was driving on the interstate when my car lost acceleration. When I gave it gas it was extremely sluggish and the CEL flashed. When I got off the gas, the CEL went away. Once I tried to accelerate again, same ordeal.
I changed the plugs and had a valve adjustment about 9k miles ago. Thoughts?
CEL will not stay on.
Old Aug 12, 2014 | 05:14 AM
Carbon Blue's Avatar
pull the code??
Old Aug 12, 2014 | 05:20 AM
There's no code to pull, the CEL isn't on.
I'm unsure on if it's stored or not.
Old Aug 12, 2014 | 06:58 AM
96-EJ6's Avatar
The ecu should store the code if there was one.
Old Aug 12, 2014 | 07:10 AM
BEASTMODE's Avatar
is it sluggish only or does it studder or hesitate and buck?
Old Aug 12, 2014 | 08:37 AM
Merknsissys's Avatar
Hmm this sounds like my issue but I was getting a P1399 code from this replaced coil packs and TPS and it turned out to be my cat collapsed inside and it flashing causing a back up and misfires on all cylinders up around 6K or higher and rite around 3200 you could feel the car hitting a wall as far as power.
Old Aug 12, 2014 | 10:11 AM
JrJanowski's Avatar
Usually a flashing cel means multiple cylinder misfire... never had this problem on my s2k but had it all the time on my Volkswagen and it was the coil packs and tps.. best of luck
Old Aug 12, 2014 | 10:32 AM
superchargedk20's Avatar
X2.
Old Aug 12, 2014 | 12:37 PM
Thanks guys, pulled a cylinder 2 miss. Will replace coil pack and start from there!
Old Aug 20, 2014 | 08:56 AM
Any update on this?
WarrenW
Nov 25, 2013 07:13 PM
psychoazn
Apr 26, 2012 08:32 AM
Importedpower
Nov 9, 2010 07:54 AM
bcohan
May 16, 2007 05:49 AM
