Lost power to drivetrain
Old Sep 28, 2012 | 12:05 PM
rocketstarter's Avatar
Default Lost power to drivetrain
Hey guys I'm on my way to Langley from Ga and lost all power to the wheels.
I was driving along in 6th at 60mph and had to nail the brakes as another car pulled into my lane. The car remained in gear. When I got my foot back on the accelerator the revs jumped but no forward momentum. I pulled out of 6th and double clutched into 3rd, revs jump las if in neutral.
I made my way over onto the shoulder and tried all gears. No forward momentum. All I get is a sound of wheezing from the drivetrain. Reminiscent of WRC gearboxes wheezing to death but not as pronounced. No leaks.
2000MY stock drivetrain 62k, fluids changed every 5k. No burnouts, no launches, no drag strip action.
I can't tell whether its the clutch, gearbox, or differential. I have all spares other then the diff.
Billman? Haha, guys all info is welcome. I need some speculations to think of on this 350 mile toe.
V/R,
-Miko
Old Sep 28, 2012 | 12:06 PM
apme123's Avatar
how is the clutch reservoir, is there any fluid? double check that and report back
Old Sep 28, 2012 | 12:10 PM
Clutch fluid full. Clutch pressure and feel are good
Old Sep 28, 2012 | 12:34 PM
On a flatbed traveling N on I-85 by exit 75, honk if you see me, I'll be people watching...
Old Sep 28, 2012 | 12:39 PM
MM3Kwolik's Avatar
Sounds like the clutch went bad...everything else is a direct mechanical linkage and you would've heard metal bits grinding about if it was your tranny or diff.
Old Sep 28, 2012 | 01:28 PM
I do hear a whining/wheezing from the drivetrain, just can't tell where. Why would anything break from hitting the brakes is what puzzles me, especially at 62k
Old Sep 28, 2012 | 01:49 PM
zeroptzero's Avatar
Did you lock up wheels under panic braking before disengaging the clutch ?, that could break something.
Old Sep 28, 2012 | 01:55 PM
I used maybe half the brake force available for a split second, the wheels didn't lock up, there was no drama from any other components other than the drivetrain
Old Sep 28, 2012 | 02:25 PM
MM3Kwolik's Avatar
Like I said, sounds like your clutch went out. If you hear whirring and the RPMS just climb with throttle, there is no power transfer between your engine and transmission. The shifter in the S2000 is mechanical unlike most other cars, so if you can go into each gear it's highly unlikely that there is anything wrong other than the clutch.
Old Sep 28, 2012 | 02:59 PM
That's what I'm thinking too. AP2 Trans will be going in next week along with a AP2 PP, fidanza flywheel and F1 clutch disc. It's just odd how it happened, and at 62k as well. Hmm
