Loud grinding sound
Old Oct 31, 2005 | 03:27 PM
prozaca's Avatar
Default Loud grinding sound
okay i have this loud metal on and off grinding sound from the back passenger side wheel... it sounds the same as when you have to change your pads cuz the sensor is hitting the disc... i changed the discs and pads and 5 minutes later the noise was back.. it takes a few minutes before it starts... I have read some old posts about hub bolts and what not, is this the same thing..there is no clicking sound this is a grinding noise like er er er er er er.... when i swerve right it goes away, when i swerve left it is louder then ever. Please help anyone...
Old Oct 31, 2005 | 03:55 PM
xviper's Avatar
Bad wheel bearing?
Old Oct 31, 2005 | 05:07 PM
Tech7427's Avatar
check out the tsb for rear hub clearances
Old Oct 31, 2005 | 05:41 PM
Slows2k's Avatar
There is no TSB on the rear hubs.
There is a service news article covering retorqueing the axle nuts, for a clicking sound when changing direction.
xviper's on the right track, you need to be looking at all the pieces that rotate on the right rear corner.
Old Nov 1, 2005 | 06:37 AM
stefluva's Avatar
I've had that noise before and it was a bad wheel bearing.
Old Nov 1, 2005 | 12:04 PM
prozaca's Avatar
okay i retorqued it and it went away, is it true it will come back in about a week or 2, should i just change out the wheel bearings? I have a new rear diff, maybe they just didnt set it right after replacing it??
Old Nov 1, 2005 | 01:41 PM
darkfx's Avatar
i have the same damn noise! its driving me nuts and i jsut got my S 3 days ago
Old Nov 2, 2005 | 07:06 AM
Elistan's Avatar
For me, that sound was a failing wheel bearing. Re-torquing the axel nut helped temorarily, but the only true fix is to replace the bearing. I bought a bearing and hub from hardtopguy for a good price, a friend dissassembled the knuckle for me, and he took it to a machine shop that pressed the old bearing out and the new one in for twenty bucks cash.
musicforthedeaf
Sep 17, 2015 10:10 AM
ljsimp
Jul 5, 2012 04:55 PM
ryanswhites2k
Apr 15, 2011 06:03 PM
quickslvr580
Aug 18, 2007 04:04 AM
ae86pwr
Jan 5, 2007 07:32 AM
