Loud Pop Sound While Closing Soft Top
Old Jan 18, 2012 | 02:39 PM
sfrederiksen's Avatar
Default Loud Pop Sound While Closing Soft Top
Hey guys,
Just as the topic title describes, my '06 S2000 is experiencing a loud and single "pop" sound while the soft top is being closed. Does anyone know what it could be, and how to fix it?
This is one of several problems I've found with the car (ie. bent rim) since recnetly purchasing it 2nd hand from someone on this forum
Old Jan 18, 2012 | 06:17 PM
Anyone?
Old Jan 18, 2012 | 07:57 PM
marlonRocks's Avatar
The loud pop im assuming is the glass getting caught on one of the metal tabs that the toneau cover attaches to. Whatever you do, do not operate your top until you remove that tab or you risk shattering your glass and having to replace the entire soft top assembly. Unfortunately, I learned the hard way, hope this helps.
Old Jan 19, 2012 | 05:38 AM
Hmm.. when I last checked, it seemed like it was bumping into the "wind breaker" glass that's between the two driver headrests. Has anyone else had this issue?
I'll check it out when I get back home on Sunday (metal tab). Thank you!
Old Jan 19, 2012 | 04:58 PM
Cawdor's Avatar
I've noticed something similar. I sometimes hear a pop after the top has been closed. Any idea what this is?
Old Jan 20, 2012 | 08:36 AM
Mine pops (it's loud) as it's closing, I'd say when it's about half way closed.
Old Jan 24, 2012 | 09:01 PM
RobHimself's Avatar
Mine also does this on occasion. But since my top is worn out I have been leaving it up. I am replacing it next week but would like to hear a resolution in case I have issues in the future.
Old Jan 25, 2012 | 04:23 AM
S2_4SHOOR's Avatar
two straps on both sides could cause this. If it's loose, it's getting caught. Mines doesn't make noise but instead, it doesn't fold down properly time to time
Old Feb 16, 2012 | 11:05 AM
FIXED IT.
I found out that, as I closed the soft top, the top edge of the soft top glass was grabbing onto the back of where the secret storage compartment pivots to open/close... somehow, the plastic in this pivot point sticks out more on the door of the secret compartment than the plastic below it, so the window gets "caught" in it and therefore makes the loud pop sound. I fixed it by adding some felt tape right below the pivot point so that the window brushes against that vs. grabbing the plastic. The sound is COMPLETELY gone!
Belkin623
Mar 24, 2021 08:48 AM
Ajjra
Jul 5, 2011 04:05 AM
caskin
Nov 19, 2010 10:37 PM
SLstone s2k kid
Feb 28, 2006 11:37 AM
VTEC Racer
Nov 6, 2002 09:47 AM
