low compression on #1 cylinder
Old Sep 29, 2014 | 05:32 AM
ek206's Avatar
Default low compression on #1 cylinder
[size="5"][size="5"][size="4"]Hey guys
Having hard time with my S2K. need some help.
Background
1. 06' with 30k. bought my s2k 3months ago and i drove less than 800miles.
2. had CEL (P0219 Over rev. P0301 missfire #1 cylinder) and VSA ! lights
3. but i swear God that i never over rev the engine.
4. did compression test 120. 200. 210. 205 also checked plugs, coils, and injectors.
5. did valve adjustment today but they were perfect nothing to adjust.
6. nothing wrong when i drive ,idle fine and no limp mode or something. just same all same except CEL light.
so what is your opinion for my S2k?
what should i check next?
Old Sep 29, 2014 | 06:15 AM
MM3Kwolik's Avatar
Could be a burnt valve that the 06+ DBW are known for. I've seen and repaired a number of them now.... even with that low of milage.
Old Sep 29, 2014 | 06:17 AM
MM3Kwolik's Avatar
A leakdown test would be my next course of action...
Old Sep 29, 2014 | 09:19 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Old Sep 30, 2014 | 06:10 PM
ek206's Avatar
Thank you Jordan and Billman
I will try leakdown test tonight and will update it.
thanks s2ki!
Old Sep 30, 2014 | 07:01 PM
Eluded's Avatar
good luck EK206, hope it's not a big repair item.
Old Oct 1, 2014 | 10:00 PM
ek206's Avatar
Thanks Eluded but im in big trouble i think. Lol
Update
First of all, did leakdown test last night.
#2. 3.4. Cylinders were ok. No air leaking. But when i put the air to #1 cylinder, i saw the air coming out from oil deep stick, header, and exhaust pipe.
So f@#ked up. Followed the every steps what manual says
Except one thing that i didn warm up the engine at all.
Before i did the test i thought at least the block was ok.
Plz help me s2ki.
Old Oct 2, 2014 | 04:21 AM
Billman250's Avatar
Top Answer: 1
First....make sure cylinder 1 was at TDC of the firing stroke.
Next, check your valve adjustment. If you find a tight exhaust valve, you can say 100% that the valve burnt due to insufficient clearance.
ALL 06-09 S2000s should be checked at 15k miles on the odometer, then 50k intervals thereafter.
Old Oct 2, 2014 | 05:32 AM
ek206's Avatar
Thanks Billman.
I ll try again as you told me.
but i have one more quick question
Is it possible to put ap1 head on my ap2 block?
Cuz my friend has a spare ap1 head. And i just wanna put this head rather than rebiild mine.
Some say it is possible to put ap1 head on ap2 block without any extra work but some say it wont fit on DBW harness.
Old Oct 4, 2014 | 02:55 PM
MM3Kwolik's Avatar
Yes it is possible, there really are no differences in the heads with the exception of the AP1 head having ports for the Secondary Air Injection system, but the DBW intake manifold will block off that port without issue. The only other difference is the valve retainers (either use your current AP2 retainers and keepers on the AP1 head or buy new AP2 retainers and keepers for the AP1 head. Also, use your cam towers, rockers/rollers, cams, and caps from your AP2 head. This will just keep everything up there at an even level of wear.
The benefit to rebuilding your current head (which would be what I would do), is that you'll be keeping the motor VIN matching to the car which will help retain value. Any time an engine is replaced or mismatching, the value of the vehicle will go down, regardless of what was done.
If you're semi local or feel like shipping me your head, I can definitely rebuild it for you. Just let me know.
Ayeeeyorandy
19
Aug 31, 2017 03:57 PM
rbtz
Dec 19, 2013 07:34 AM
s2k0utlaw
Mar 23, 2013 01:04 PM
extraspicytuna
Mar 17, 2013 05:30 AM
Harrower
Jul 17, 2011 12:27 PM
