Low compression
Old Mar 22, 2023 | 03:14 PM
Static sean's Avatar
Originally Posted by Save the Manual Wagons!
So, which is it?
the second numbers that’s exact numbers frm the pictures I have
Old Mar 22, 2023 | 03:17 PM
Originally Posted by windhund116
How is the car running? How is the engine idling? Starting? Will it run into VTEC range okay? Burning oil?
Thanks!
It has a lil rough idle. It dose hit vtec an Revs out fine to my knowledge. Starts fine. A yes it dose burn oil. But it dose feel “slow” but it’s hard to gauge that since It’s all I know. I haven’t driven another s2000 besides mine so I don’t know if what I’m feeling normal or not.
Old Mar 22, 2023 | 03:20 PM
The compression test results will depend on your tester. You said you got consistent numbers at 180-190.
Why are you worried about this? What results would you like to see?
it was a matco compressor. Im just more or less wanting a good healthy engine. I was under the impression 220 n up is healthy numbers for a used s2000 motor. I’m just not super sure about specific engine stuff on s2000s.
Old Mar 22, 2023 | 03:21 PM
Originally Posted by noodels
engine fault codes or light on dash?
no fault codes no dash lights.
Old Mar 22, 2023 | 06:12 PM
B serious's Avatar
I would find a reputable S2000 shop to do a leakdown test.
If the leakdown is excessive, then figure out where the compression is going.
Then there can be meaningful recommendations.
It doesn't really seem like there's anything wrong with your car though. It may be best to just leave it alone, assuming the shop that changed your retainers did a good job.
You went with a set of stock AP2 retainers, correct?
Old Mar 22, 2023 | 08:48 PM
ty. n I think so tbh it’s been over a year since I did that an it’s been sitting not sure though
Old Mar 23, 2023 | 06:01 AM
noodels's Avatar
So prob head/valve related rather than another engine needed,and not cheep today and value of used engines are many $ks?
That would make your old engine very sort after if just had head problems
Old Mar 23, 2023 | 07:10 AM
B serious's Avatar
I would make sure they replaced the valve retainers AND cotters with AP2 parts. It's extremely important to be sure so that you don't have issues later.
Old Mar 23, 2023 | 08:09 AM
Car Analogy's Avatar
If you have this engine rebuilt, its almost a guarantee resuot will be lifespan will be significantly less than if you do nothing and just drive it. Thats assuming there is an actual issue, and it isn't something simple like a valce adjustment.
These engines simply cannot be successfully rebuilt by anyone except shops that specialize in rebuilding them, and even then doesn't always end well.
Old Mar 23, 2023 | 09:23 AM
Save the Manual Wagons!'s Avatar
What you're saying and/or what the shop(s) told you is all over the place. There's no way we can diagnose this though forum posts.
There must be a shop in the Bay Area that knows S2000s. Take the car there.
GomezWvC
Jun 22, 2013 09:33 AM
wickwirew
Mar 11, 2013 09:14 AM
bd307
Sep 7, 2010 02:53 PM
CrazyPhuD
35
Aug 21, 2010 11:14 AM
JDMQuip
San Diego S2000 Owners
15
Feb 13, 2007 03:57 PM
