Low compression in my s2k
Old Oct 27, 2016 | 10:31 AM
Car Analogy's Avatar
Originally Posted by Jesman-built
yeah, the battery put it in the trunk and the boot is always some voltage drop, can this be a factor, take this into account thanks
Yes, definitely. The engine must be cranking at a good rate to get a good compression reading.
Also, as someone already mentioned, throttle must be held fully open (WOT = Wide Open Throttle). Engine warm. No fuel going in (remove the fuel pump fuse). Etc.
Remove all the spark plugs to make it easier for engine to crank fast.
Since your battery is in trunk, maybe use a second battery, with thick jumper cables, hooked up to battery terminals at front of car, so you'll have two batteries in parallel. Or just temporary move battery back to front of that is easier. Make sure its fully charged and healthy before test.
Old Oct 27, 2016 | 11:06 AM
Jesman-built's Avatar
thank you very much, all advices I maded when I did the tests but now come from my garage to remove the battery of the trunk, tomorrow i will relocate the battery in its original place because I was also giving starting problems due to voltage drop by the so long wire from the trunk. tomorrow ill made the compression test other time, I hope it goes better.
Old Oct 27, 2016 | 01:45 PM
Well, male sure the battery is fully charged. If its been laboring in the trunk, working harder to start engine, working harder to get a charge, its probably not fully charged now. Through a charger on it overnight before you test compression again.
Old Oct 28, 2016 | 10:41 AM
Mijae007's Avatar
does holding the throttle pedal down affect 06+ dbw s2000s?
Old Oct 28, 2016 | 05:11 PM
windhund116's Avatar
You just want to insure max air flow into the cylinders, from the intake. True whether drive-by-wire, to not.
Old Oct 30, 2016 | 02:34 AM
For the dbw cars, gas pedal won't work. You have to remove intake hise, then prop the throttle plate open with something. Make sure its not something that could get sucked into intake.
jungle
Mar 5, 2019 09:18 AM
s2kbtos
Nov 8, 2015 11:06 PM
762
Nov 19, 2010 04:51 PM
s2kflorida
Jun 7, 2010 07:07 PM
jert534
Jul 18, 2006 06:38 PM
