Lowering spring problem
Old Aug 22, 2009 | 06:46 PM
WomenBeShoppin's Avatar
Default Lowering spring problem
We just installed skunk2 springs but there is a problem now. at around 40 mph when I give it gas, the car vibrates alot, it feels like its coming from the rear. Any clues what could be the problem? BTW the lug nuts are tight.
Old Aug 22, 2009 | 08:10 PM
Avionics86's Avatar
Did you preload the suspension before tightening everything?
Old Aug 22, 2009 | 08:20 PM
No we didn't, you think that would cause the vibrating from the rear?
Old Aug 22, 2009 | 09:10 PM
s2k83's Avatar
did you install the driveshaft spacers, if not, thats your reason for vibrations most likely, search " drive shaft spacers" and you'll see what I am talking about, you can buy two piece spacers so they'll be easy to install.
Old Aug 23, 2009 | 08:28 PM
No i didn't. The car has over almost 100k on it, so that could be the case. Would it be OK to drive my car with its current problem for a few weeks before I put in the spacers?
Old Aug 23, 2009 | 08:38 PM
Tanikins07's Avatar
Bad alignment? Everyone I talk to always suggest that after lowering your car you definitely should get an alignment.
Old Aug 23, 2009 | 09:39 PM
s2k83's Avatar
With that milage, I am almost positive thats the problem, in my opinion its never a good idea to keep driving a car with issues, or the fix gets more expensive.
Old Aug 24, 2009 | 08:55 AM
03-toda-s2000's Avatar
wait about a week to do the alignment so the springs set in
Old Aug 25, 2009 | 02:38 AM
schefdeh5's Avatar
I say get an alignment done. I just dropped mine, but I don't have that problem.... I'm gettin an alignment done on Friday iA.
And what do you mean the "rear" shakes? You don't feel it in the steering wheel?
Old Aug 25, 2009 | 05:38 AM
vtec9's Avatar
Go back and untighten everything then pre-load and re-tighten. Then wait a week and get an alignment.
EP3'sSuck
Dec 30, 2015 09:50 AM
saving4one
Jul 29, 2014 06:04 AM
S2k007
May 22, 2012 10:35 AM
Blacknot
Dec 27, 2008 03:17 PM
negcamber
Jun 24, 2006 03:56 AM
