LSD Help ASAP Please!!!
I think you are free wheeling in Neurtral, but in Gear with the drive shaft engaged etc....then the differential is engaged and you should spin opposite directions. I doubt your car would work at all if the diff was broken because the inner workings of a diff make it impossible to not have the counterrotation and still be able to power the wheels..
I agree...stay away from the BROWN acid......
LSD (lysergic acid diethylamide) is one of the major drugs making up the hallucinogen class. LSD was discovered in 1938 and is one of the most potent mood-changing chemicals. It is manufactured from lysergic acid, which is found in ergot, a fungus that grows on rye and other grains.
LSD, commonly referred to as "acid," is sold on the street in tablets, capsules, and, occasionally, liquid form. It is odorless, colorless, and has a slightly bitter taste and is usually taken by mouth. Often LSD is added to absorbent paper, such as blotter paper, and divided into small decorated squares, with each square representing one dose.
The Drug Enforcement Administration reports that the strength of LSD samples obtained currently from illicit sources ranges from 20 to 80 micrograms of LSD per dose. This is considerably less than the levels reported during the 1960s and early 1970s, when the dosage ranged from 100 to 200 micrograms, or higher, per unit.
The brown acid reference has to do with Woodstock, the great hippie concert where there were mass announcements, one of such was,"don't take the brown acid," because it was bad...
Originally posted by DJHohum
whats the deal with the neutral thing?
The "Test" requires the car to be in gear, if the car is not in gear, you are not doing "The Test" what's the problem here
s2kAtTracks
Jun 28, 2007 02:09 AM
