Lubrication points
Old May 7, 2005 | 06:35 AM
smed's Avatar
Post Lubrication points
I was just about to change the oil on my S2K for the first time using the How to instructions on S2KI and I was wondering if someone can tell me what area's need to be lubricated and where can I find them (also what lubrication should I use).
Old May 7, 2005 | 06:53 AM
xviper's Avatar
There are no "zerk" fittings on this car and thus, you don't really "lube" it (like when you go get an oil change and a "lube job"). If you really feel the need to do it, you'll have to tap and install all these fittings in all the ball joint boot areas.
However, you can still take care of the rubber boots themselves - something that most owners neglect.
https://www.s2ki.com/forums/index.php?showtopic=113452
Of course, there's all the door, hood, trunk latches and hinges to squirt some White Lithium Grease onto and all the rubber weather seals on the windshield, soft top, hardtop, under the hood and under the trunk lid to treat with some sort of silicone grease.
toztigger
Aug 1, 2019 06:44 AM
JGSS2K
Feb 22, 2009 07:41 PM
rukawa88
Oct 11, 2002 02:13 PM
rukawa88
Oct 11, 2002 04:51 AM
Poordogs2001
Feb 28, 2001 12:25 AM
