main relay clicking
Old Sep 13, 2017 | 06:16 AM
blink962's Avatar
Default main relay clicking
hi
i have some battery drain issue. battery drain around after 6 day?
today when i installed a charger on it, i noticed the main relay underdash was clicking when the charger is on..
what's the issue?
Old Sep 13, 2017 | 06:40 AM
windhund116's Avatar
Maybe, a parasitic draw?
Old Sep 19, 2017 | 12:32 AM
misfit2009's Avatar
I had a similar sounding problem for months, although occasionally mine would die whilst I was driving it - turned out my dodgy Honda UK alarm was pulling the switched live to the main relay low and then occasionally low enough to actually disconnect the main relay whilst driving. Although it would usually let me run the starter motor (but the ECU was powered down so it wouldn't start)
Old Sep 19, 2017 | 02:32 AM
Chuck S's Avatar
Main relay?
There's constant battery draw on modern cars including the S2000. Else the radio memory would not work and the key fob would not lock or unlock the doors. Same for OEM and aftermarket alarms. 6-days to battery death is not normal. Car battery is not a deep cycle type and only a couple of complete discharges below (say) 10 volts will damage it to the point it will not recover.
Have your battery tested and see if you can find how much of a parasitic draw you have. There will be some.
-- Chuck
Old Sep 20, 2017 | 02:26 PM
blink962's Avatar
found my parasite draw,i drain 0.03 amp now
Old Sep 20, 2017 | 03:51 PM
Nice! What was the parasitic draw?
I believe 0.03 (30mA) is within normal operating limits.
Good job!
Old Sep 20, 2017 | 04:54 PM
blink962's Avatar
my tuner hooked my mac boost temporally on my alternator ...
i had it not hooked when i went to tune it last week.
thanks guys!!
farmerdave
Feb 2, 2010 10:13 AM
TheDonEffect
Aug 13, 2008 10:40 PM
Stiggywig
Feb 12, 2008 10:25 AM
Ro_Ja Boy
Jan 18, 2007 08:26 AM
gus
Nov 6, 2002 12:56 AM
