Main and Rod BEARINGS
Old Feb 26, 2007 | 11:52 AM
CaymanS2k's Avatar
Default Main and Rod BEARINGS
quick question. I need to get new rod bearings, and also main bearings.
got the numbers and letters from the block and crank..here is what i got.
CRANK B B C C
3 3 4 4 3
BLOCK C C B C C
Can anyone help me with what colors i need please? and explain what colors go where?
Thanks
webster.me@gmail.com
Please let me know asap.
Thanks
MW
Old Feb 26, 2007 | 12:28 PM
s2kBryan916's Avatar
In my opinion I would take measurements of the crank and rods to make sure there was no damage done. Honda has the different sizes (color) bearings and you should be able to find the correct bearings with the measurements.
good luck
Old Feb 26, 2007 | 12:33 PM
CaymanS2k's Avatar
no damage is done, just thought since i'm pulling the engine down i would change the bearings. Just need to know what numbers or letters i need for the color. on the bearings they have D1D A. is A the color?
Old Feb 26, 2007 | 12:40 PM
For the bearing codes your going to want to look on the side of the crank webbing.
The code will have four letters and five numbers underneath.
The letters are the connecting rod bearing codes.
The numbers will be the main bearing codes.
Edit : Your also going to want to know the big end bore codes for the connecting rods your using. (oem rods will have this code half on the rod and half on the caps)
Old Feb 26, 2007 | 03:14 PM
CaymanS2k's Avatar
and also about how much would everything cost
Old Feb 26, 2007 | 03:26 PM
If you want the connecting rod bearing colors you will need to get the numbers off of the connecting rods (big end bore).
The main bearings (with the codes you gave) are as follows :
Journal #1 = green/brown
Journal #2 = green/brown
Journal #3 = green/brown
Journal #4 = brown
Journal #5 = green/brown
As far as costs go ... your going to have to find a dealer and get a quote.
UH-60DRIVER
Feb 12, 2019 01:02 PM
HippoTuning
Oct 15, 2013 09:29 AM
supahman04
Jan 27, 2008 04:04 PM
Big Bird
Nov 15, 2006 06:14 PM
S-EMPIRE
Oct 23, 2006 10:39 PM
