maintainance light
hi
when i start my car the maintainance indicator blinks for 10 secs. then it goes away, is it due to a fuse or any wiring ( i haven't put anything on the car, electric or performance) or im i just to stupid to realize that it needs to go on the dealer for maintainace. it has 80,000 miles, and seh just got back from the dealer. the brakes front and back got replaced also their was a recall on the spark plug so that got fix, i checked the manual to see what other things im required to do maitainace wise and most of the task is done except to change the tranny fluid, rear diff fluid and check the parking brake adjustment.
sorry if this is to long but i want to be specific to make it easier for you guys to recomend what i should do next
thanks
thanks
Key OFF, press & hold BOTH the trip reset and select buttons, key on, continuing holding the buttons until the MRL resets. If that doesn't work, then https://www.s2ki.com/forums/index.php?showtopic=183490
Somebody please stop me from responding to MRL reset posts.
