Maintenance light blinking, Diff fluid help!
Old May 24, 2010 | 08:33 PM
LBCS2000's Avatar
Default Maintenance light blinking, Diff fluid help!
Okay, so i have a ap1 and i would like to know how do u guys take the bolt off for the differential bolt (top one) to put in fluid, i know it uses a 23mm but it was very hard and the bar frame was in the way from getting any leverage to unscrew with the socket wrench.
-when i turn on my car my maintenance lights blinks 4 times, i just changed engine oil, spark plugs, and tranny fluid, but not differential fluid i changed diff fluid 3k a while ago is it because diff fluid is low?
Old May 24, 2010 | 08:43 PM
LBCS2000's Avatar
https://www.s2ki.com/forums/index.php?showtopic=348700
if u guys can see it's the first picture idk if this car's a ap2 but the bar space for me is not that big o.o
Old May 24, 2010 | 10:10 PM
Stealth_SUX_'s Avatar
You know the maintenance light is for engine oil.. And has to be reset by u. it doesn't monitor your diff.. and it doesn't reset itself
Old May 25, 2010 | 03:43 AM
spets's Avatar
There's got to be some way you can get a flat wrench on there. Try flipping it over if it is angled? or try the other end?
Old May 25, 2010 | 04:04 AM
mlc's Avatar
mlc
Hold down the reset button and turn the key to the on postion. Hold the button down for about 5 to 10 seconds and the light should go off.
Kevin
RedCelica
Aug 27, 2016 02:48 PM
XtC-604
Jan 22, 2010 08:59 PM
id003
Sep 23, 2009 09:11 AM
s2k bandit
Aug 20, 2009 08:53 PM
news2kroller
Apr 1, 2006 11:18 PM
