Maintenance required light
Old Aug 4, 2009 | 03:30 PM
zzziippyyy's Avatar
Default Maintenance required light
Ok, Ive had my car 8 years and ive reset this light many times over the 107k miles i have driven it. Over the weekend the maintenance required light on the dash lit up. So nbd i said as soon as i got home i went and did the standard reset routine. Key in off hold trip button turn ignition to on wait for light to go out. Well all it does is blink off for half a second and than stays lit?
Any ideas?
To clarify the standard routine to reset is not clearing it.
Thanks
Old Aug 4, 2009 | 04:20 PM
s2k dre's Avatar
U have to hold both of the buttons with key on. The trip and select buttons.
Old Aug 4, 2009 | 04:50 PM
zzziippyyy's Avatar
Thanks but that didnt work
Ok here is what has been done
Trip button help while cycling key didnt work
Trip and select button held while cycling key didnt work
Sel button held while cycling key didnt work
Im at a loss
Old Aug 4, 2009 | 04:56 PM
s2k aok's Avatar
with over 100K miles i'm pretty sure you've learned to take care of your car. let the light burn out so you won't ever have to mess with it again.
Old Aug 4, 2009 | 05:35 PM
zzziippyyy's Avatar
^ either that or ill take the cluster off and pull the light
Actually i think its an electrical glitch itll prob reset when i pull the posi terminal off the battery for a while...
Old Aug 4, 2009 | 07:04 PM
SgtB's Avatar
I have to hold the trip button for over a minute sometimes. It's hit or miss.
Old Aug 4, 2009 | 08:01 PM
Slows2k's Avatar
Turn the headlights off if they are on..
Drive a few miles and try again. Driving and lights off will usually take care of it.
Old Aug 5, 2009 | 03:39 AM
zzziippyyy's Avatar
Done it all, nothing above has worked
Old Aug 5, 2009 | 01:55 PM
zzziippyyy's Avatar
Ok update, after really getting frustrated with it i took a sledgehammer to the dash and obliterated it, only thing is now the speedo does not work
J/K J/K
I sat there and held the trip button for 3 minutes and finally it reset end of story.
pli
Nov 9, 2008 10:55 AM
SLstone s2k kid
Dec 14, 2006 07:23 AM
designfreak
South Florida
May 11, 2004 04:45 PM
doorman
Feb 22, 2004 06:07 PM
Vash
Oct 14, 2003 12:13 PM
