MAP sensor
Old Sep 2, 2005 | 08:44 AM
jason4207's Avatar
Default MAP sensor
What is the MAP sensor, and why are people 'whacking' them? How do I know if my MAP sensor needs to be whacked? How do I know if it needs to be replaced? Do you just hit it with a screwdriver handle or something? I tried a search on "MAP sensor", and nothing relevant popped up.
Old Sep 2, 2005 | 09:08 AM
xviper's Avatar
"Whack" was an affectionate term I used to describe what is done. You don't really "whack" it. You just give it a firm knuckly thump or two in case there is debris caught up in the hole. The main thing is to unclip and re-clip the wiring harness to make sure the connection is fresh and an ECU reset doesn't hurt either if all else has been tried and doesn't resolve whatever is that's ailing the car.
All this is described in detail in the FAQs.
Old Sep 2, 2005 | 09:42 AM
dozen5's Avatar
and here it is
"map whack"
Old Sep 2, 2005 | 10:58 AM
jason4207's Avatar
Thanks guys...I thought I had looked all through that section....now I see it though.
And thanks for the link.
Old Sep 2, 2005 | 11:10 AM
japoneeZ's Avatar
if you were curious about what the map sensor does, it converts manifold absolute pressure into electric signals into the ecm. '=)*
s2kseven
Aug 11, 2019 04:23 AM
amdaman
May 20, 2015 01:35 AM
s2konroids
Jul 12, 2010 12:13 AM
veehexx
Aug 8, 2009 03:32 AM
F1s2000
Dec 12, 2003 01:57 PM
