Master cylinder?
Old Mar 9, 2014 | 09:54 PM
tcjensen's Avatar
Default Master cylinder?
Hey guys,
I used to get a brake bleed and end up with a super firm pedal.
Now, after a gravity bleed by a respected Motorsports shop, then another gravity bleed by me, then another gravity bleed by a respected mechanic, then another vacuum bleed by the same mechanic (after a change to new brake pads and rotors, as well as stainless brake lines) ... My brake pedal is still kind of mushy with too much travel.
There's no way it's a bad bleed after so many of them, by different people, and in different ways. It's shouldn't be the pads after a pad switch, and it's not the rotors since they are new ... As are the lines.
There's no CEL. Do you think installing a new master cylinder will fix this issue? The brakes still work. It's just that the pedal travel and feel is a bit inconsistent. And it goes down annoyingly low, making heel-toe downshifting under hard braking more difficult than it used to be (because my foot hits the side I the gas pedal as I swing it over). I've continued to autocross, but I'm scared to go to the track, since something might be wrong and be magnified at the worst possible moment ...
Thanks for any help ...
Tom
Old Mar 10, 2014 | 05:41 PM
Gottabfast's Avatar
Have you tried bleeding right after some ABS stops? If you have air in the modulator it could cause similar issues
Old May 14, 2014 | 10:03 PM
tcjensen's Avatar
Thx for advice! Your post led me to eventually do Robinette's MC bleed through the ABS line on the car and my pedal is finally much better!
Old May 16, 2014 | 04:16 PM
Gottabfast's Avatar
No problem! Glad it's fixed!
DaveUK
Sep 16, 2023 12:24 PM
Boostmaniac
Jun 20, 2017 03:26 PM
Moddiction
May 4, 2015 07:40 AM
Moddiction
Aug 31, 2011 09:04 AM
Ali_houston
Jun 24, 2009 04:58 PM
