Max fuel pressure with stock injectors?
How much fuel pressure can the stock S2000 fuel injectors handle before the either malfunction, or spray pattern deteriorates? Thanks
What is the flow of the stock injectors? I'm considering larger injectors but if the upper rate of the stock injectors is sufficient perhaps I can just up them a little.
I'm pretty sure the stock injectors are running well below 80% at peak, but I could be wrong. You could buy an OBD-II datalogger if you really want to find out. www.obd-2.com.
C. Bender
2001 Silver/Black
Turbonetics TO4B 60:1 Ball Bearing Turbo; Tial 46mm Wastegate and 50mm Blowoff Valve; GReddy EGT and Boost Warning Gauges; Speedcraft Front Mounted Intercooler, Mandrel Bent Tubing, 3 Inch Down Pipe, and 3" Stainless Exhaust; A'PEXi N1 Mufflers; AEM EMS, Fuel Pressure Regulator, and Wideband O2 Sensor; RC Engineering 550 Injectors; Holly 250 Forced Induction Fuel Pump; Oil Filter Relocation Kit with Stainless Steel Lines; Clutchmaster Stage 3 Clutch; Toda Lightweight Flywheel; Mugen Radiator Cap, Thermostat, and Fan Switch; Upgraded Oil Bolts; Hecash Brake Ducting; Competch Stainless Steel Brake Lines; WorkMeister S2R 18" Wheels; Spoon X-Brace; Muz Shift Knob; Lucid's Front and Rear Speakers; 2002 Stereo Head Unit; Rick's Front Badge; JDM Clear Side Markers; Uber Cool Nurburgring Decal
C. Bender
2001 Silver/Black
You might also call RC Engineering (rceng.com) and speak with a tech support guy. They may have tested S2K stock injectors and may be willing to share what they learned with you. I found them to be very helpful.
CB
CB
