Mechanical O2 Simulator
MY06+ are kinda funky with the TP CEL. Sometimes the mechanical o2 fix doesn't work...sometimes it does.
For an MY03...I'd give the spark plug anti-foulers a try since they are 1/4 the price of the Blox. If it doesn't work then you can pick up the Blox and not be out all that much money.
This trick works great. I have been using this on my06 with 70mm invidia for over 10000 miles no cel no problems. Works on any car with heated downstream 02's. Have used a version of this on three different mustangs and one civic as well with good results.
Going to throw my input in here. I put a full exhaust system on my 2002 AP1 at the beginning of the year (header, test pipe, & catback) and I put the 2 defoulers on the test pipe and it worked like a charm.
Fast forward to now. The AP1 is gone and I'm now in a 2006 AP2. I saved the exhaust system from the AP1 and it's now on my AP2 and I got a CEL after a day of driving or so. A local friend has the exact same exhaust setup on his 2005 with the 2 defoulers and he doesn't have a CEL issue.
I've read a good bit and saw the 3 and 4 defouler trick work and not work. I've also read about the steel wool trick work and not work. I'm thinking about just ditching the test pipe and getting a Berk High Flow Cat. Thoughts?
Just my $0.02.
Just my $0.02.
