Mechanical O2 Simulator
um... no don't try it with just one non fouler... I did it and it did not relocate the o2 sensor far enough out of the direct path of the exhaust and I threw a CEL right away... changed it back to using both of the non fouler pieces and everything was fine...
thanx again SLO-S2000 great fix it thread...
Originally Posted by SpoonS,Sep 28 2004, 07:15 AM
OK TWO IT IS with the spoon test pipe it hangs down pretty low i guess i will just have to be careful
I didn't realize you had the spoon...I have a custom so mine doesn't hang down at all I think.
Hey guys, I've got a rather hard question. I'm about to install a Venom computer controlled NOS system on my S2K, it uses readings from the 02 sensor to tell me whether the car is running rich or lean. Which, I'm told is crucial, because running lean means engine damage. Can I run a test pipe with this O2 trick, or do you all think that the sensor being out of the direct air flow will give me a poor reading?
atiently waits:::
