Mechanical O2 Simulator
I am running the T1R exhaust and test pipe... loud, yes .... too loud, not for my taste...
you should be fine if you are running the amuse exhaust you will be able to notice only a very small increase in the volume but a nice deeper note that really sounds how the car was meant to sound!
Originally Posted by Trip,Oct 2 2004, 04:36 PM
in simple terms, what you are doing is placing the O2 sensor further away (inclosed in a tube) from the cat...right ??
Just for the record...I'm at about 2700 miles so far on this mod, and getting ready for an oil change
Originally Posted by SLO-S2000,Oct 3 2004, 09:05 AM
Yep...thats it...its out of the direct flow, and also less exhaust passes by it...so what it sees, seems normal to it as if the cat was there...
regards
Juan
Originally Posted by S2000_Europe,Oct 3 2004, 03:12 PM
what about the performance? any change?
regards
Juan
regards
Juan
Originally Posted by Trip,Oct 3 2004, 03:20 PM
Since there is no CAT there is less restriction, therefor less back pressure. Isn't back pressure essential on an N/A engine ?? It would definitely increase engine response but what about torque at low revs ?
http://www.p1auto.com/jack/s2k/s2kexhaust.htm
Originally Posted by SLO-S2000,Oct 4 2004, 07:31 AM
Check this out...it isn't my car...but it is another member from the board
