missfire issue
Old Oct 15, 2007 | 05:41 PM
DRE.'s Avatar
Default missfire issue
Ive been having a slight missfire for some time now. It only happens at idle, or when turning the car on off (its kind of stumbles off). Anyhow, I replaced the plugs for a new set of OE plugs, I replaced the coils, I adjusted the valves..... After all that the car has better fuel consumption, it accelerates smoother, but its still getting throwing on the a CEL 1399, and 0304 (I think thats it cant, I know its missfire cylinder 4). So what else should I troubleshoot?
Andres
Old Oct 15, 2007 | 07:12 PM
negcamber's Avatar
Injectors
Old Oct 15, 2007 | 07:17 PM
DRE.'s Avatar
Originally Posted by negcamber,Oct 15 2007, 10:12 PM
Injectors
all of them?
Old Oct 15, 2007 | 07:50 PM
negcamber's Avatar
I ended up going for all 4. I had misfire in 2 cyl and then ordered the injectors after reading up on the code here on the forum. By the time the injectors arrived, was seeing 3 cyl codes.
It is something in the design of the injectors...they just seem to have a limited life span for some reason.
You can clean em and get a bit more milage out of them, but others have said that is pretty temporary.
Old Oct 16, 2007 | 04:29 AM
DRE.'s Avatar
ohh, sweet looks like ill be buying four injectors. Thanks
Andres
Old Oct 16, 2007 | 05:47 AM
gregnm369's Avatar
I also had 4 injectors replaced to fix a misfire.
Old Oct 16, 2007 | 05:50 AM
asecondsworth's Avatar
I had an issue with misfires, but I was lucky and only needed 4 spark boots.
OvaDaLimiT
Apr 13, 2023 10:16 PM
Simann
Jul 10, 2010 01:01 PM
silvery2ks2k
May 18, 2009 07:13 PM
jojipoji
Nov 8, 2007 01:03 PM
preppyS2000
May 3, 2006 01:28 PM
