More interior light woes
Old Jun 25, 2008 | 08:26 AM
Peter Pantless's Avatar
Default More interior light woes
Recently I noticed that the interior (windshield) lights nolonger came on when either door is opened with the main switch set to any position. The lights will come on if I hit the individual light switches but only if the main switch is set in the center position. They will not come on at all if it is set to 'ON' or 'OFF'. I believe the driver's door-jam switch is working correctly because I get the annoying beep if the key is in the ignition when the door is open.
Anyone had any problems with the master switch mounted on the light assy? Is there something obvious I'm overlooking? Can I have a ham sandwich please?
Old Jun 25, 2008 | 09:29 AM
cdelena's Avatar
I had problems with the light and tracked it to bad ground... the lights are grounded by the mounting screws and previous work had lost or loosened parts.
Old Jun 25, 2008 | 10:13 AM
s2kdiggler's Avatar
i have the same problem with my trunk! it only comes on after my trunk is open for a while
Old Jun 25, 2008 | 05:35 PM
Thanks for the advice.
I checked the ground and it is making good contact. Both door jam switches are verified as working (via the 'door open' light on the dash when the ignition is on.
Anyone ever had the switch itself go bad?
I'm guessing that I have to remove the interior windshield trim panel to remove the switch and light assembly...
Anyone???
Bueller???
Old Jun 25, 2008 | 08:54 PM
BEASTMODE's Avatar
Mine sometimes flickers on and off. Dunno why though.
Old Jun 26, 2008 | 10:50 AM
froggie's Avatar
I had exactly the same problem with my light. Ended buying a new unit, and voila, everything back to normal.
Also, you do not need to remove the windshield trim to do this: Just remove the lens, and with a flat screwdriver, carefully pry it out; but don't forget to remove the two screws at the bottom of the unit.
Hope it helped.
Old Jun 26, 2008 | 01:29 PM
Thanks!
Will let you know.
Old Jun 26, 2008 | 01:56 PM
You ROCK froggie!
I took the assembly out and took apart the sitch. It was all corroded so I cleaned it up and everything works fine now!
Thanks for the heads-up!
DaMan22
Sep 5, 2013 11:23 AM
ryanfeldman
Aug 29, 2013 07:20 PM
s2konroids
Mar 20, 2010 04:46 AM
dh01s2k
Apr 10, 2007 10:59 PM
the fretking
Nov 25, 2004 04:34 PM
