Morning engine light
Old Oct 16, 2008 | 09:56 AM
AeroS2000's Avatar
Default Morning engine light
this morning i woke up and turn on the car. The Check Engine light came on. so i quickly turned the engine off and pop the hood to see whats goin on. Found 2 smalls hoes that was disconnected from the breather line. Must have gotten disconnected from doin a intake cleaning and changing the air filter. so i reset the ECU and turn on the engine again and the Light went off. But last night i drove it after i did the cleaning and no lights but this morning lights.
Old Oct 16, 2008 | 10:07 AM
vincewchan's Avatar
Go to your local auto store and scan for the code
Old Oct 16, 2008 | 10:20 AM
AeroS2000's Avatar
The code is gone now and i drove it to work cause the Truck had no gas.
No Engine lights the whole drive.
Old Oct 16, 2008 | 09:42 PM
Kirpich's Avatar
OK, there's a OBD plug under passenger side dash, short pins 4 and 9 with a paperclip, and turn on ignition. Your CEL will give you a 2 digit code for reference, by flashing. they are general codes that are not as specific as the standard OBDII codes.
Old Oct 17, 2008 | 07:58 AM
AeroS2000's Avatar
sorry i miss word. I ment the CEL went away after I reconnected the two small hoes and reset the ECU.
Does the ECU needs to be reset for the CEL to go away?
Old Oct 17, 2008 | 11:15 AM
SuzukaBlueAP2's Avatar
Originally Posted by AeroS2000,Oct 16 2008, 01:56 PM
Found 2 smalls hoes
what a great morning find!! LOL
You should still take it to auto zone and have the OBDII scanner hooked up to see if it stored a code.
Wayners
Nov 1, 2010 03:45 AM
GaryB
May 11, 2009 11:39 AM
noverby
May 8, 2009 07:29 PM
windle
Jun 17, 2008 08:57 AM
Congo
Dec 4, 2005 09:52 PM
