Most recent 1-2 grind fix?
Is the 1-2 grind fix TSB that's posted here the most recent version, or have there been amendments?
https://www.s2ki.com/library/service/2ndgeargrind.php
Thanks,
s.8k
Thanks,
s.8k
As far as I know there is only one version of that particular TSB.
Lots of people still have this problem but you hear much less about it when the ambient temperature in North America is low. The symptoms are much more apparent with heat, so you will see more posts in a few months. It is yet to be seen if the '02's are past the issue.
Originally posted by todaysivxx
i thnk its called mis shifting....quick and hard....thats how i do it.
My '02 has a funky second gear...sometimes it makes a screeching sound when I downshift to second. It's not grinding...it just "squeeks" as I slide it into the gate. But it only happens when I downshift. Other times when I'm going from 1st to 2nd it is hard to engage, but no grind yet. I'm keeping my eye on it.
jimbo69ny
Feb 27, 2003 09:53 AM
