My 2.5L Stroker Engine Buildup Thread
Originally Posted by Guedo512,May 11 2006, 05:44 AM
yes, i would like to know about this also...
It's the ol' cumbustion chamber volume + headgasket volume minus the piston dome volume at TDC equals final volume. Initial volume BDC : final volume TDC gives the compression ratio i.e. 11:1. When they blueprint the engine these should end up being the same from cylinder to cylinder.
Ya, what did the CR turn out to be?
Originally Posted by MikeR90S,May 11 2006, 10:53 AM
Newbie question... why are the top decks of Inlinepro's and S2000NVegas different? Inline's has an open water jacket around the bores whereas Vegas has a closed deck with discrete water holes?
Mike
Mike
both work the same, no difference between the two. We had this block already sleeved, and i purchased it.
Originally Posted by ya@inlinepro,May 11 2006, 10:33 AM
still haven't CC'd the head yet so, i'll get you a final CR soon!
But i'm sure it'll be 13:1 and yes its daily driven on pump gas...
ya.. good luck with the build, cant wait to see the #'s. you guys always make quality product! i will be making a trip to VA for a "saturday drive" when its finished. my turbo will be installed in a week and a half. ill email ya pics and #'s of the finishied product!!!!!!!1
doing some more checks before assembling everything.
CC'in the head now
Valve clearance check
and the head of the beast as it sits.
the head is NOT fully assembled yet. Hope to have everything assembled soon.
CC'in the head now
