my 4.77 gear problem
Old Feb 15, 2004 | 12:12 PM
Sush Boi's Avatar
Default my 4.77 gear problem
hi guys, i was wondering if u guys can help me out. i bought a used 4.77gears with the pumpkin last month and just installed it. when i test drove it i can feel the difference but also it make this weird noise from the rear. especially when im slowing down. did anyone else have this problem? does the fluid i put in the gears make a difference? i added NEO synthetic gear lube sae 75-w-90 h/d
thanks
mark
Old Feb 15, 2004 | 12:26 PM
RazorV3's Avatar
maybe the backlash wasn't set properly... 75w90 synthetic sounds good to me.
Old Feb 15, 2004 | 01:03 PM
RWD_RCKT's Avatar
Make sure your fluid was made for limited slip differentials.
If it was made for limited slip, then maybe you should try some friction modifier from Redline to maybe help rule out the limited slip itself.
Old Feb 15, 2004 | 02:26 PM
xviper's Avatar
Doesn't sound like the gears were calibrated properly to begin with. Is this Neo-syn meant for diffs?
Here's a current thread that may be of interest to you:
http://forums.s2ki.com/forums/showthread.p...threadid=170332
HondaJB
Oct 4, 2014 11:14 AM
adamisaacddr
Oct 15, 2008 02:36 PM
SDosMil
Sep 11, 2006 08:34 AM
news2kroller
Jul 26, 2006 02:35 PM
tothemaxx
Sep 22, 2005 04:00 PM
