My dipstick keeps poping out
This happens when i drive the car hard. The o-rings on seem like they are still working and i installed Krankvents but it still pops up and i cant figure out why. The car dynoed 215whp and doesnt seem to have excessive blow by and valves are adjusted perfectly. I have never had this problem before
I have a stock 06 and my engine dipstick did the same thing. I bought a new one at the dealer and the problem was solved. Never pops out anymore even when driving hard. I believe it was a slight defect in the o-rings.
Adam
Adam
Adam
Adam
My dipstick keeps poping out, any ideas
I had the same problem on another car. It had to do with a bad valve adjustment and my pcv valve was bad ( too much pressure in valve cover) . Not completely sure that it would have the same effect on the S because there is a vent straight into the intake.
you also have Krankvents, wich are pretty much overkill for non boosted applications. Make sure they are working. With the vents there should be even more vacuum that would hold the stick in.
I'd prolly go with everyone else on this one, Inspect the o rings on the dipstick. Go to a hardware store and get thicker ones if you need to.
Originally Posted by jeggy,Nov 11 2008, 07:02 PM
too much viagra is not a good thing. stick to the directions.
