My solution to dipstick popping out.
Old Oct 5, 2009 | 02:10 PM
AFs2k's Avatar
Default My solution to dipstick popping out.
I got tired of checking to see if I had to push my dipstick in in the morning before going to work so I decided to "fix it."
I need to know if this will cause any problems down the road. I checked to see if my PCV valve is working and it was. I even gave it a quick blast of brake cleaner to make sure it was clean.
The spring is from a box of carb. springs I had left over for my 240z from AutoZone. The hole in the dipstick is very small.
Pics: (I am not a photographer.)
Old Oct 5, 2009 | 05:12 PM
SC_Highlander's Avatar
I like it. I don't see any reason it would cause any problems.
Old Oct 5, 2009 | 05:19 PM
SilverS2kF22C1's Avatar
Hmmm why is the dipstick popping up? When I have seen this in the past on other cars there is severe crankcase pressure build up due to a damaged piston...
Old Oct 5, 2009 | 05:26 PM
CKit's Avatar
Or you could have just turned the dipstick 180 degrees. It works very well.
This a common thing with our cars. Clean the o-rings with a rag and rotate it.
Old Oct 5, 2009 | 05:34 PM
FISH22's Avatar
[QUOTE=SilverS2kF22C1,Oct 5 2009, 08:19 PM] Hmmm why is the dipstick popping up?
Old Oct 5, 2009 | 06:01 PM
AFs2k's Avatar
I don't think my car has any problems at all. I make great power and I have NEVER burned oil. I am always right at the H.
I just did this because I was tired of checking to see if it was up or down. I don't want any dust or heaven forbid sand to get in there. Trust me, I'm anal.
Now I have peace of mind, and for only what... 3 mins of my time and maybe 30 cents for the spring.
Old Oct 5, 2009 | 09:05 PM
soulicious's Avatar
After hard driving, mine used to pop-up all the time (NA and FI) even when the dipstick was turned 180 degrees. Adding Krank vents helped solve this issue.
Old Oct 5, 2009 | 09:18 PM
Saki GT's Avatar
Afaik 4cyl engines like ours vibrate horribly, especially at higher rpms, and the thing shakes loose. never thought about pressure popping it off.
Old Oct 6, 2009 | 04:24 AM
Hmmm didn't know that, never noticed mine popped out. Now I'll keep my eye out for it.
Thanks!
Old Oct 6, 2009 | 04:39 AM
S2000_FUN's Avatar
Excellent mod Can't see any reason this can go wrong
