Strange electrical fault
Old Dec 12, 2014 | 01:15 PM
japcrap's Avatar
Default Strange electrical fault
Hi Guys,
Got stuck in some bad traffic the other day and decided to get my GPS out to find an alternative route. Plugged in the charger into my cigarette lighter and the stereo went straight off. As soon as I take the charger out the stereo comes back on, very annoying knowing where you are going but with no music or not knowing where you are going but have music. Has anyone had this problem and does anyone know how to sort it out? Thanks in advance.
Old Dec 12, 2014 | 06:00 PM
Car Analogy's Avatar
The stereo uses 2 fuse circuits. One of them is connected to the cig lighter socket. So if something blows the fuse on the cig socket, you lose the stereo too.
But you didn't blow a fuse. Since after unplugging it worked again. All I can think of is the gps used too much juice, but not enough to blow the fuse, just enough to prevent radio from working.
That seems odd. Another possibility is someone put too high a fuse into this circuit, and gps used too much (charger is bad, etc) which should have blown fuse but did not. That would be BAD. So check the fuse size asap.
Old Dec 24, 2014 | 08:30 AM
japcrap's Avatar
Checked the fuses, all ok there. I managed to get both working the other day by plugging the charger into the socket before turning the car on and this seemed to solve it, I could take the charger out and put it back in again and everything was ok. But I tried again today and the stereo went off At a bit of a loss with what to do next but think I'm going to have a look at the stereo earthing.
Old Dec 24, 2014 | 08:45 AM
Ap2low's Avatar
I've read it's the accessory relay I believe?
Old Dec 24, 2014 | 08:55 AM
japcrap's Avatar
Can you shed some more light on that? I.e how do I fix it?
Old Dec 26, 2014 | 09:09 PM
turbo_slug's Avatar
Problem is caused by dirty contacts on the "load shedding relay".
It's a grey relay located under the dash.
Easiest fix is to pull the relay, pop the relay cap off, then clean the contacts
Somm2k
Jun 25, 2014 01:29 PM
rubenzfst
Oct 20, 2006 02:19 AM
Thistler
Aug 19, 2005 09:45 AM
CA_Brit
Apr 13, 2005 04:51 PM
Karl O.
Jul 12, 2004 05:11 PM
