MY04 has small areas of rust
I've had a couple Hondas with that, they call it Honda cancer btw.
My last car I ground it down smooth to shiny metal, so it wasn't perforated rust, more like surface rust. Sprayed it with rust converter and primer and a topcoat until I could have it repaired by a body shop, it didn't look so great but I felt better putting an end to the spread of it and getting down to shiny metal. If it gets to bubbling and being perforated then it will get worse and need more repairs including cutting out and replacing as noted above.
I've seen some self-repairs that can be done even if it's perforated, but they are temporary & hard to make look nice. Especially if there are sharp body lines.
Now that HondaPartsNow is making s2k parts. I did find a full rear quarter panel, that would then need to be installed, primed & painted. I'll have to get some estimates & see if this is the most cost effective thing to do.
https://www.hondapartsnow.com/genuin...s2a-310zz.html
Spray the wheel arches from the inside with your preefered brand of rust proofer or wax. Do it again after a few years.
The flat spot of the arch, where the screw of the bumper is located, need extra care. Spray it from the underside (Wheel side ) with your prefered underbody wax. Especially arund the plastic nut for the bumper screw.
The black trim pice around the arch is a good idea by Honda, preventig paint chiping from gravel and water from creepin between the panels; however, it need to be removed from time to time and controlled. Again, use your favourite brand of rust proofer before you put the black trim back on. Something greasy is preferd at this spot, marine grease for example.
Coil222
Dec 24, 2019 04:48 PM
