Need to find bulbs for AP2 headlights
I need both bulbs that go in the upper corner - the amber turn signal, and the small clear one for both headlights. But can't decipher from the chart exactly which ones I need to buy. Please help. Thank you.
the parking bulbs are 194/168 mini wedge, the turns are 7443 wedge. or if you wanna spend more money, you can switch to LED here, it cost me $55 for two of each bulb and load resistors
http://www.superbrightleds.com/cgi-bin/sto...isp=%2F1157.htm
i'm running ap1 lights naked with smoked metallic reflectors and amber LED bulbs
I don't really understand what those numbers mean. I just want to buy the OEM lights form the site in my second post, but can't figure out the diagram as to which ones I need to purchase exactly
Not exactly sure what bulbs you are using as mine is an ap1, but
part 18 is the parking lamp (smaller size) part 20 is the turning lamp (larger size), part 7 is the HID headlight bulb, and part 25 is the high beam bulb.
The bulb sizes and descriptions are listed in the owner's manual if needed.
Osram Sylvania has a lighting application guide. Just pick an AP2 model year.
http://www.sylvania.com/ConsumerProducts/A...placementGuide/
The numbers are standard bulb numbers. Is there any particular reason you feel the need to order bulbs from Majestic?
nope no reason. Majestic is the only that I knew of that sold the OEM parts like this online and everyone was talking about them at one point. I'll check your link, too. thanks
Hiroprotaganist
Feb 25, 2002 02:09 PM
