Need help fast! Door handle install
Old Jan 13, 2005 | 01:04 PM
Bryant's Avatar
Default Need help fast! Door handle install
Long story short, handle on my car broke in half and I need some help on taking the old one off and putting the new one on. Door panel and the two 10mm bolts that hold it to the car are off, but I cant figure out how to get the lever from the handle the lock disconected.
Is there an online helms someplace that I can just look it up?
Old Jan 13, 2005 | 02:36 PM
Bryant's Avatar
its the outer handle, forgot to say.
EDIT: Picked up a Honda Service Manual. Should have this done in no time now.
Old Aug 17, 2008 | 07:02 PM
s2kridin's Avatar
im in the same spot i m bought some cf keyless door handle and i cant get the stock handle out if you can figure it out pm so i can get this project done
Old Aug 17, 2008 | 07:39 PM
s2k aok's Avatar
shave 'em, they're broken anyways...
Old Aug 17, 2008 | 08:20 PM
Avionics86's Avatar
Remove the spring steel clip (pull it down) that holds the lock cylinder and slide the inner door handle bracket out of the way. Hope this helps.
lethals2000
Aug 20, 2010 10:45 AM
krnmike
Mar 28, 2010 12:59 PM
peters2000
Nov 8, 2009 08:27 AM
lethals2000
Aug 2, 2009 04:10 PM
StreetLegalGoKart
Mar 28, 2008 10:32 AM
