need help with iat sensor
Old Mar 14, 2012 | 11:54 AM
towingtime's Avatar
Default need help with iat sensor
Im pretty sure my iat temp is too high. normal driving is at like 170f right now. over 180 at a stop. when i unplug the sensor it drops to -40. is it maybe a bad sensor ?
Old Mar 14, 2012 | 12:30 PM
T-Smac's Avatar
It's normal for it to read -40 when unplugged. As for the 170, that does seem a bit high. It will be getting some heat from the engine, but I wouldn't imagine that much.
Are you having any drive-ability concerns?
Old Mar 14, 2012 | 04:48 PM
towingtime's Avatar
OK i figured it out today, But yes the car has been low on power which is why i started to diagnose it. It turns out that my aftercooler coolant wasnt flowing properly and it was getting too hot. It had an air pocket keeping it from flowing! runs better now though
Old Mar 14, 2012 | 09:22 PM
towingtime's Avatar
The car has noticeably more power now. Does the computer adjust the timing or something when the iats are that high like mine were? it was running "good", as in smooth, no missing or hesitaion, just seemed weaker.. Now that the iats are way lower, under 100 with the supercharger and everyhthing, its running way better..
Old Mar 14, 2012 | 11:42 PM
T-Smac's Avatar
Warmer air is less dense. Since the ecm saw this "less dense" air, it dumped less fuel than it should have.
Old May 7, 2012 | 09:44 AM
uLmighty's Avatar
How do u find out what the temperature is?? I just installed a k&n Fipk intake without drilling a hole for the sensor. Instead, I put the sensor on the other hole where you suppose to cover it..
WebMasterP
Mar 19, 2013 03:33 AM
earl's_f20c
Sep 30, 2012 11:17 PM
KyleAtwood
Mar 19, 2012 08:09 AM
2js2k
Aug 8, 2009 09:09 AM
